Home > Technical (L322) > Speaker for handsfree
Dean_C
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Anyone know where the speaker is for hands free Bluetooth system?
It is really crackling & popping, I’m hoping it’s just a worn out speaker rather than Bluetooth ecu.
The other audio / radio speakers are sounding fine. So guessing this is a separate speaker for the system hidden away somewhere.
Post #690024 5th Apr 2024 8:19pm
dhallworth
There isn’t a separate speaker. It uses the same speakers that the audio system uses.
If you put some music on with some decent bass and turn the volume up enough, can you hear any of your individual door speakers rattling or popping? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #690029 5th Apr 2024 9:56pm
The Bluetooth control unit's are often swimming in the boot as they are the most exposed ECU im afraid sir... Mad
Post #690034 6th Apr 2024 12:02am
Dean_C
Thanks for the advice, I will investigate further.
Audio system seems fine even cranking up the volume.
I will take a look at the Bluetooth controller for signs of water ingress.
Thanks again people, this forum is brilliant Smile
Post #690040 6th Apr 2024 7:24am
Dean_C
Done some more diagnostics, all the electronics in the left rear boot panel have extra plastic covers over them. Except the parking ecu this has been swimming in water unfortunately.
I purchased an ecu reader on recommendation from here.
MaxiAP200 £50 delivered. It’s a brilliant bit of kit.
I had to replace two lower suspension arms & thought I might need it to calibrate the height.
Used to reset service warning & update new battery fitted.
Plus I’ve done a full service, with a cheap Amazon sucker £45 just about fills it.
Got oil from opie along with maan filter about £70 delivered.
So looked into the audio system for errors. I got three circuit speaker errors & the dreaded “lost comm’s with parking assist ecu”
I’ve only scanned a few systems yet & air conditioning is cold but not ice 🧊 cold, had gas level check & it good.
Question is anyone know locations of speaker 6 & 2 & 1 ?
Oh got two new tyres also oem Pirelli scorpion zero, mot, insurance & tax, quite expensive month.
Post #692009 6th May 2024 11:32am
