![]() | Home > Technical (L322) > Speaker for handsfree |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
There isn’t a separate speaker. It uses the same speakers that the audio system uses.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
The Bluetooth control unit's are often swimming in the boot as they are the most exposed ECU im afraid sir... |
Dean_C Member Since: 30 Apr 2021 Location: Lancashire Posts: 41 ![]() ![]() ![]() |
Thanks for the advice, I will investigate further.
Done some more diagnostics, all the electronics in the left rear boot panel have extra plastic covers over them. Except the parking ecu this has been swimming in water unfortunately. I purchased an ecu reader on recommendation from here. MaxiAP200 £50 delivered. It’s a brilliant bit of kit. I had to replace two lower suspension arms & thought I might need it to calibrate the height. Used to reset service warning & update new battery fitted. Plus I’ve done a full service, with a cheap Amazon sucker £45 just about fills it. Got oil from opie along with maan filter about £70 delivered. So looked into the audio system for errors. I got three circuit speaker errors & the dreaded “lost comm’s with parking assist ecu” I’ve only scanned a few systems yet & air conditioning is cold but not ice 🧊 cold, had gas level check & it good. Question is anyone know locations of speaker 6 & 2 & 1 ? Oh got two new tyres also oem Pirelli scorpion zero, mot, insurance & tax, quite expensive month.
