Home > Technical (L322) > Hunter alignment specs for l322 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3071 |
The wheel alignment specs are in the workshop manual downloadable from this site's Wiki section 2012 TDV8 Vogue (L322) |
3rd Apr 2024 8:00am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4289 |
It will be different for sure.
3rd Apr 2024 8:20am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35117 |
my L405 hunter adjustment from kwik fit was specced as a L322 because of my '05' personnel reg number..
3rd Apr 2024 9:32am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 779 |
my TDV8 2011 L322 was Front Toe +9° Rear Toe +12° |
3rd Apr 2024 11:55am |
Klunk Member Since: 12 Jul 2021 Location: North wales Posts: 72 |
Thanks all, really helpful.
3rd Apr 2024 1:41pm |
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 69 |
I went to kwikfit a while back for new boots and the ‘experienced’ fitter came in to the waiting room to tell me there wasn’t any adjustability on the rear. Looked on his screen and he had it set up to something like an 89 Range Rover…….
3rd Apr 2024 7:19pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 379 |
I had my alignment done and although everything was green and looking correct it veered to the right when driven, had it looked at again but this time with the engine running and it showed a different reading. Once it was tweaked it drove straight.
4th Apr 2024 11:40pm |
With the engine running the car will have the suspension active to level itself. Idealy you would also use a workshop tool to set the suspension in tight tolerance mode preferably after doing a suspension height calibration. 2012 TDV8 Vogue (L322) |
5th Apr 2024 6:44am |
It also needs half a tank of diesel in it and locked into Tight Tolerance Mode Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th Apr 2024 9:24am |
Hopefully not a silly question but - what is tight tolerance mode and how is it in engaged? 2009 pre-facelift 3.6 TDV8. |
5th Apr 2024 11:53am |
Continual height adjustment rather than only when it’s +/- 10mm in normal use. Needs a capable diagnostic tool such as the GAP IID 2012 TDV8 Vogue (L322) |
5th Apr 2024 12:31pm |
