Home > Technical (L322) > 4.4 TDV8 Oil Leak - do I travel this easter? |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Oil cooler gaskets and / or feed-pipe O-rings. Do NOT do 3000km - you'll regret it.
27th Mar 2024 12:38pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3188 |
Check for oil in the coolant header tank. If it's clear you should be OK for your big trip as long as you keep an eye on the oil level. Also check for a leak around the oil filter as this is the only service related possible cause. There are no common issues with catastrophic oil loss on these engines. 2012 TDV8 Vogue (L322) |
27th Mar 2024 1:11pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
It is also worth checking that the drain valve under the oil filter itself is still on it's locating post if the filter has recently been changed. |
27th Mar 2024 1:43pm |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 34 |
I didnt notice anything around the oil filter or cooler, but not sure i have right knowledge or understanding to properly investigate. Though Im convinved leak is from lower down than the oil filter. 2011 Vogue SE 4.4 TDV8 |
28th Mar 2024 5:37am |
Check out this for a good explanation
28th Mar 2024 7:33am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 798 |
Losing 0.5l sounds a bit much for just the turbo feed pipe o rings
29th Mar 2024 8:06am |
