Home > Technical (L322) > aerosus on an 2005 4.2 SC
JackPeters125
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Hi all,
I am looking to replace my front bags and struts as one has a leak. I have seen on Advanced Factors, and other sites that there is a specific strut for the 4.2 and later models.
On Aerosus they only seem to have one option.
https://aerosus.co.uk/land-rover/range-rov...strut.html
I called and they said it was compatible but wonder if anyone on here have used them on an early 4.2SC?
Do top mounts just need swapping over?
Am I better off spending the extra and getting OEM from somewhere?
Post #689058 26th Mar 2024 4:49pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Did mine last year got them from island 4x4 Thumbs Up
Post #689074 26th Mar 2024 6:35pm
JackPeters125
Did you go for the Dunlops or the OEM stuff?
Post #689080 26th Mar 2024 7:11pm
MR GLOVER
OEM Thumbs Up Was easy to do one bolt was a Censored Laughing WD40 NEEDED Laughing
Post #689165 27th Mar 2024 7:29pm
JackPeters125
Nice one. I ended up ordering some OEM stuff and spare bolts. Just gotta find the time to fit it all now! 😄
Post #689168 27th Mar 2024 7:52pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I went OEM (BWI) from Advanced Factors, fitment straightforward and quick delivery. All good a few thousand miles later. ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #689453 30th Mar 2024 8:36pm
JackPeters125
Cheers guys. I went with BWI and it all turned up from island 4x4 yesterday.
Just to find some time to do it!
Post #689471 31st Mar 2024 6:39am
JayGee
Doesn't need much time with the right tools. I did mine in less than an hour per side and that included dealing with the CVD wires which yours doesn't have. My tips;
Jack the whole front to equalise load on the ARB. If you can only do one side turn the wheel and undo the ARB bolt before jacking that side. An impact driver is a must for removing the lower nuts and bolts and don't think you can just use on a big breaker bar. Propane torch in reserve if you need to heat the knuckle to extract rusted bolts. Remember the ABS cable routing as it's easy to get this wrong when putting the new strut on. If you are working alone use a small jack to raise the hub to position the top bolts rather than trying to lift with one arm and reach over with the other. Mark the 2 outer bolt positions with felt tip as these are slotted / adjustable for camber. You don't need to deflate the system as you can slowly release the air from the connection to the top of the strut. You will need a very short 12mm spanner to do this ( cut an old one down) also you will need 16 and 18mm sockets and spanners which some sets don't have. I reused the airline fasteners and found reataching them fiddly and I wasn't confident I had got a good seal until a few days later when the car had been stood and not dropped. Good luck but it's quite an easy job apart from the physicality of heaving big parts around if like me you are out of practice..... 2012 TDV8 Vogue (L322)
Post #689485 31st Mar 2024 8:41am
JackPeters125
Finally got around to starting the job today.
Thanks for all the tips. You were right. Pretty easy with the right tools. The bottom bolt was a right pain. Lots of heat and a bigger hammer and it eventually budged though.
Just done the one side but should be all good for the other side at some point soon.
Post #690526 13th Apr 2024 4:58pm
