Home > Maintenance & Mods (L405) > Lower tailgate problem
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Hi folks
My lower tailgate has started playing up. About half of the times I close it the right hand side doesn’t lock in and I have to give it a push. Is this a known fault? What’s the fix?
Many thanks 2017 (67) Vogue SE Corinthian Grey
Post #687765 11th Mar 2024 9:20am
worth checking if you have a boot mat that is creeping forward and just preventing it closing fully. I had that in mine.
As a matter of course, lubricate the locks each side with WD40 too. Discovery 4 HSE
Post #687771 11th Mar 2024 9:50am
Gremlin500
@Abacus 405:
Worth checking the alignment of the entire tailgate, the upper is known to drop and affect the lower.
Stand behind the closed-up car, and carefully examine the shut lines, if these are all OK, only then look at adjusting the latches.
Powerful UK have a few good videos on YouTube re tailgate alignment, if that’s what’s needed. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #687774 11th Mar 2024 10:15am
Abacus405
Dull result!
Removed the lower tailgate trim panel, lubricated both ends of the strut, as much of the pivot as I could, the ball end at the body attachment, both hinges. It’s now working. 2017 (67) Vogue SE Corinthian Grey
Post #688154 15th Mar 2024 2:26pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
Sounds like a good result to me, problem fixed and no dollars down First time FFRR owner
Post #688171 15th Mar 2024 6:51pm
WeeJ
Slightly different problem with L405 lower tailgate
Rolling Eyes I've read through all the previous lower tailgate issues and I recognise some of the symptoms but my issue seems to be different.
My lower tailgate switch only works once and then stops until I follow a certain sequence again.
When I open the full tail using the key fob, both halves open smoothly. In this status the lower tailgate button pressed causes the lower tailgate to close (smoothly) but thereafter the switch doe nothing. With the full tail open, the button on the upper causes both halves to close correctly.
These actions suggest to me that there's no mechanical cause to the lower half not working and the fact that a press of the button closes the lower half suggest s the switch is ok. I replaced the switch just in case but it made no difference. Tried all the reset functions with fully open tailgates, didn't do anything.
Would the two pinch sensors have an impact. I believe I can test their open/close easily. Update: I've tested both pinch sensors and they are working ok. I had thought they would operate as the door closes and perhaps their status be part of the logic for open/close, but they only sense obstructions and don't 'make' when the lower tailgate closes. Looking at the rubbers and alignment, I don't think they should but I can't find confirmation of that.
Thoughts, ideas? I'm suspecting the control unit, but dunno where it's located or I'm grasping at straws. Would a fault diag tool help? Rolling Eyes 1998 Freelander XEdi
2003 Freelander HSE
2006 Freelander V6
2006 Disco 3 TDV6
2012 Range Rover Vogue L322
2014 Range Rover Vogue 2014 L405
2017 Range Rover Vogue 2017 L405
2021 Mercedes GLE400d AMG Premium Line
2024 Range Rover Westminster 2021 L405
Post #688283 17th Mar 2024 4:53pm
