Home > Maintenance & Mods (L405) > Trim ring
supershuttle
Trim ring
Well after 45 yes of marriage ( too late to change now) SWMBO declared she was cold so I told her to turn the temperature up on her side. “What was that little ring thing that fell off?” Never to be seen again - I can’t actually remember where I got them (all 3) can anyone remind me?
 Geoff
Post #687132 4th Mar 2024 11:12am
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
Geoff,
It's only that I'm bored at work that i looked into this, but they come from Ebay (they are an after market mod, not RR)
But I do like the Autobiography badge you have placed there!
Copy and paste should find it (set of 4 ) you'll have 2 more spares and a radio button spare, or you could look for it, it will most likely be down the side of the seat somewhere.
https://www.ebay.co.uk/itm/385533121597
Post #687135 4th Mar 2024 11:33am
Gremlin500
Hi Geoff,
Lots of these on AE if you do a search, probs exact same stuff as eBay and usually cheaper, delivery usually takes a month or so, but so can CN suppliers on eBay. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #687137 4th Mar 2024 11:37am
supershuttle
After investigation g I know where it’s gone - into the hole/void under the passenger seat and my big hands don’t fit, I’m not taking the seaT out to get it back. I just stuck the Autobiography badge on because I didn’t like the big blank space that was there. Not sure if the trim rings are magnetic if so I might try a magnet on a piece of string.
Thanks for the replies. Geoff
Post #687144 4th Mar 2024 12:24pm
supershuttle
What am I thinking, it’s made of aluminium so a magnet will be of no use. Very Happy Confused Geoff
Post #687147 4th Mar 2024 12:33pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
The L460 will drive your OCD mad then with the big gap below screen!!
Post #687157 4th Mar 2024 1:29pm
supershuttle
It'll be a while yet - I read no really positive comments on here re: L460 Geoff
Post #687160 4th Mar 2024 1:44pm
supershuttle
goldeneye32 wrote:
Geoff,
Deffo cant find it so ordered Geoff
Post #687161 4th Mar 2024 1:46pm
JCW
If you remove the four bolts securing the seat rails to the floor, you should be able to tip the seat back against the rear seat to gain access, without removing the seat or unplugging anything. Jonathan
2007 Defender 90 XS Hardtop
Post #687162 4th Mar 2024 1:47pm
supershuttle
Wouldn’t you just know it, retrieved the trim after giving it another go (it was in the hole in the floor) and of course just ordering replacements. When they arrive I’ll do the controls in the back and experiment to find how best to fix them in place. Geoff
Post #687171 4th Mar 2024 2:47pm
goldeneye32
Geoff,
I think you'll find they are self adhesive strips, and the adhesion dry's out after a while, when the cabin gets hot/cold/hot/cold etc
Then they fall off!
G.
Post #687181 4th Mar 2024 3:50pm
supershuttle
That is indeed what has happened, double sided tape dried out. I think I'll just use glue as its not likely I'll be removing them - well not intentionally that is Very Happy Geoff
Post #687182 4th Mar 2024 4:06pm
Kot
We definitely need a "Like" button! Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #687190 4th Mar 2024 5:07pm
