Home > Maintenance & Mods (L405) > Oil Leak
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Oil Leak
I seem to have a small oil leak, right hand side looking at the engine. I assume it is most likely the oil cooler gaskets or O-Rings. What is the be way to see this before taking anything apart. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #686571 27th Feb 2024 10:20am
luxmoggy
The coolant looks clean. SDV8 AB MY 2020
Post #686603 27th Feb 2024 1:48pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I bought a camera for the purpose of locating leaks.
【Dual Lens】Teslong Endoscope... https://www.amazon.co.uk/dp/B0CF9GSF4T?ref=ppx_pop_mob_ap_share
edit - camera stopped working! now ordered a Depstech DS530 £92 from Amazon...
Post #686605 27th Feb 2024 2:09pm
luxmoggy
I have now ordered one.
I am hoping it could be from the filter, As that was changed by the garage in October. I started to see drops of oil in December. The oil has gone down less than 1 mark in 3 months. SDV8 AB MY 2020
Post #686606 27th Feb 2024 2:19pm
Kot
If you suspect oil filter, check the oring is in the correct position and not damaged/flat etc and ensure it's not cross threaded when you re-instal, and use a Torque wrench!.
Did find when I first got my vehicle the dealer apprentice used a tippex mark! 2018 SE SDV8 4.4 Byron Blue
Post #686611 27th Feb 2024 2:32pm
luxmoggy
I have used the endoscope. I don't think it is the filter. The dripping is increasing.
Is it best to go up or down with the camera to see the back of the oil cooler? I tried a bit from the top but I wasn't so good with the camera. Where should I try and get the camera to go?
I am getting the feeling this is going to be the oil cooler gaskets and o-rings. Where else could the oil be coming from. SDV8 AB MY 2020
Post #686683 28th Feb 2024 2:52pm
luxmoggy
Just remembered I took out an extra warranty. So will ask if the oil leak is covered before I do too much. SDV8 AB MY 2020
Post #686696 28th Feb 2024 4:58pm
Gremlin500
Fingers crossed! Good luck! Very Happy “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #686698 28th Feb 2024 5:06pm
Kot
Could also be the 2 dreaded Orings on the rear of the Engine best done when cooler off.
Gasket
But this is more fun with christian Thumbs Up
Post #686703 28th Feb 2024 6:47pm
luxmoggy
Found that Christian is about 2 hours from me.
I have watched that video. SDV8 AB MY 2020
Post #686705 28th Feb 2024 6:50pm
luxmoggy
Garage will check next week.
Each checkmark on the oil level is 300ml?
I am down 4 check marks. I put in about 300ml-400ml and it seems to have gone up a mark.
That would make the oil loss 1-1.5 in 4 months. SDV8 AB MY 2020
Post #686792 29th Feb 2024 3:18pm
luxmoggy
The importance of having the car on flat ground. I was in a car park this evening and remembered to check the oil level before driving home. I am only down 1 mark after topping up. So I haven’t lost as much oil as I thought I had.
A little oil can make a big mess on the driveway. SDV8 AB MY 2020
Post #686805 29th Feb 2024 5:34pm
luxmoggy
Car was at the garage today. It will be fixed on the extended warranty. They will call Monday to arrange. SDV8 AB MY 2020
Post #687575 8th Mar 2024 7:50pm
