Home > Maintenance & Mods (L405) > Oil Leak |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 467 |
The coolant looks clean. SDV8 AB MY 2020
27th Feb 2024 1:48pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 333 |
I bought a camera for the purpose of locating leaks.
27th Feb 2024 2:09pm |
I have now ordered one.
27th Feb 2024 2:19pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1228 |
If you suspect oil filter, check the oring is in the correct position and not damaged/flat etc and ensure it's not cross threaded when you re-instal, and use a Torque wrench!.
27th Feb 2024 2:32pm |
I have used the endoscope. I don't think it is the filter. The dripping is increasing.
28th Feb 2024 2:52pm |
Just remembered I took out an extra warranty. So will ask if the oil leak is covered before I do too much. SDV8 AB MY 2020
28th Feb 2024 4:58pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1502 |
28th Feb 2024 5:06pm |
Could also be the 2 dreaded Orings on the rear of the Engine best done when cooler off.
28th Feb 2024 6:47pm |
Found that Christian is about 2 hours from me.
28th Feb 2024 6:50pm |
Garage will check next week.
29th Feb 2024 3:18pm |
The importance of having the car on flat ground. I was in a car park this evening and remembered to check the oil level before driving home. I am only down 1 mark after topping up. So I haven’t lost as much oil as I thought I had.
29th Feb 2024 5:34pm |
Car was at the garage today. It will be fixed on the extended warranty. They will call Monday to arrange. SDV8 AB MY 2020
8th Mar 2024 7:50pm |
