Home > Maintenance & Mods (L405) > Cv boot debacle
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Cv boot debacle
Sorry for the long post.
I drove through France last week, and after a rest stop going round a roundabout I heard a clicking noise, sounded like a stone in the wheel, video attached.
https://youtube.com/shorts/4MWuR3PM2lg?si=LCaSOZab-ERvRpaO
When I straightened up the noise went away, so I assumed the stone had gone and drove the 300 miles to my destination.
When I left the autoroute however the noise had returned, but only on lock. I put the car in high mode and had a look underneath.
Disaster! The cv boot had come apart.
I took the car to a garage, and to cut an already long story short they replaced the whole drive shaft.
I picked the car up and started the drive home. Yep, the noise started again after the first rest stop.
The new cv boot had done the same as the first.
I’ve packed the joint with cv grease and put a new band on, but the noise persists.
I’ve used an endoscope to get a video of the cv joint whilst the noise is happening but it doesn’t seem to be getting hit by anything.
?si=wIPIGndnxUAjOS9O
Does anyone have any ideas 2017 (67) Vogue SE Corinthian Grey
Post #685921 18th Feb 2024 5:28pm
fisha
Are you sure they replaced the whole shaft, or just took the existing off and replaced the boot then refit.
It’s possible there is grit in there and with a disassembly, clean and repack it’d be fine, but equally it could be done and need replaced. V8 or else ...
Post #685929 18th Feb 2024 9:17pm
dingg1
Hmmm, just replaced the boot imo, and made an arse of it.....
If the boot slipped, a new cv joint wouldn't deteriorate that quickly to be noticeable.
They've pulled your pants down most likely.
Post #685930 18th Feb 2024 9:38pm
Abacus405
Edited:
I’m going to take the drive shaft off and replace it. I should be able to tell if it was a new one or if the garage ripped me off. If they have I’ll try a credit card charge back on them. 2017 (67) Vogue SE Corinthian Grey
Post #685938 19th Feb 2024 7:09am
goddo
Surely you will be able to tell what they have done by looking at the invoice?
A new drive shaft is a lot more expensive than a rubber boot.
Unless, of course, you have been ripped off.
If that's the case, Im sorry for you but it does sound like more work than a boot is required.
Post #686072 20th Feb 2024 4:05pm
Abacus405
Invoice is for new drive shaft 🙁 2017 (67) Vogue SE Corinthian Grey
Post #686073 20th Feb 2024 4:11pm
Gremlin500
Next time, ask them to keep the old part, or mark it in a discrete way before you take it in. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #686074 20th Feb 2024 4:17pm
