Home > Technical (L322) > Does my car definitely come with a FBH? 043AV
Cinderrella
Hi all,
I have this fob however, car only blows out cold air when pressing on.
I have read that some cars may not actually have the FBH / Heater option... My build sheet states [022AY];Park Heating - Park Heating With Remote Control [043AV]
Does my car definitely have the heating function? I've tried to find the FBH under the bonnet but unable to find it?!
I have a webasto specialist coming out to me next week but no point calling him out if I don't have the heating function!! Can someone help?! 😭
Post #685811 16th Feb 2024 10:33pm
mjdronfield
It’s under the passenger front wheel arch, sort of under the battery. It’s exhaust is down where the front mudflap would go.
It will only heat at low temperature I believe.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #685814 16th Feb 2024 10:41pm
mjdronfield
https://www.fullfatrr.com/gallery/albums/u...er_fbh.PDF
https://www.fullfatrr.com/gallery/albums/u...rt-t91.pdf 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #685815 16th Feb 2024 10:44pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
That's one point, the other point is; you need petrol (or diesel)! Your petrol tank must be between 1/2 and 3/4 full otherwise the heater will not start.
You should also be able to hear the pump, a constant "click" sound.
Post #685822 17th Feb 2024 7:24am
Cinderrella
Thanks guys,
If I have the fob and the telestart module in the back do I definitely have the FBH? Could it be that some cars only provide ventilation for the summer?
I can't seem to find the FBH unit....
Post #685824 17th Feb 2024 7:33am
Ansi
The unit is located under the wheel arch panelling on the passenger side, under the battery as mjdronfield already said. If you look under the car you can see the exhaust, small silver coloured flex pipe.
It is quite possible that the pump is not working
Post #685825 17th Feb 2024 7:39am
Cinderrella
Can't see it 😭
I note on the instructions provided above it states that there is an option to switch on summer / winter mode. My fan is only producing cold air could it be that my car is in summer mode? I don't know where the summer / winter option is?
Post #685841 17th Feb 2024 10:01am
mjdronfield
You will have to take the front wheel arch liner out or look behind it. It was standard on all diesels.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #685868 17th Feb 2024 4:14pm
