Home > Technical (L322) > Does my car definitely come with a FBH? 043AV |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7800 |
It’s under the passenger front wheel arch, sort of under the battery. It’s exhaust is down where the front mudflap would go.
16th Feb 2024 10:41pm |
https://www.fullfatrr.com/gallery/albums/u...er_fbh.PDF
16th Feb 2024 10:44pm |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 144 |
That's one point, the other point is; you need petrol (or diesel)! Your petrol tank must be between 1/2 and 3/4 full otherwise the heater will not start. You should also be able to hear the pump, a constant "click" sound. |
17th Feb 2024 7:24am |
Cinderrella Member Since: 03 Jan 2024 Location: Leicester Posts: 42 |
Thanks guys,
17th Feb 2024 7:33am |
The unit is located under the wheel arch panelling on the passenger side, under the battery as mjdronfield already said. If you look under the car you can see the exhaust, small silver coloured flex pipe.
17th Feb 2024 7:39am |
17th Feb 2024 10:01am |
You will have to take the front wheel arch liner out or look behind it. It was standard on all diesels.
17th Feb 2024 4:14pm |
