Home > Technical (L322) > Centre propshaft bearing!
garyRR
As I am selling my L322, I put it into my local garage for a full mechanical check to see if any work needed doing prior to sale, and they told me there was some play in the centre propshaft bearing.
Having read the stories on here of it being easier to replace the whole propshaft with something like the GKN I was preparing myself for an expensive bill.
Turns out that so long as your propshaft is in good condition, it's pretty easy to replace. They've done several on L322s before and all it took was 2 hours. Total cost inc parts £180 Inc VAT.
So, if anyone in the South needs their's done, I know a garage in Southampton who will gladly do it at a very reasonable price. 2015 Range Rover Autobiography 4.4 SDV8
Post #685665 15th Feb 2024 9:15am
DrRob
Nice work 👍
Jordan Jamieson did one on his channel recently too 👍
?si=MlLtr6kaTBLWj5Dv Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #685667 15th Feb 2024 9:25am
GGDR
what an excellent seller you are!! Cheers, Greg
Post #685670 15th Feb 2024 9:56am
DrRob
I’ll be doing the same when the time comes Thumbs Up
Gary and I are of the same mindset Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #685678 15th Feb 2024 1:26pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Maybe it's a Hampshire thing? Rolling with laughter ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #685682 15th Feb 2024 2:24pm
rryan
United Kingdom 2010 Range Rover Vogue TDV8 Buckingham Blue
Hi Gary,
Apologies for resurrecting a 7 month old thread but I stumbled across this looking into my symptoms - the car's, not mine!
You mention you had yours sorted in Southampton, which is around the corner from me - would you kindly share who did the work for you and I'll make some calls?
Many thanks in advance!
Ryan 2009 facelift L322 3.6 TDV8 - Buckingham Blue
Post #701093 29th Sep 2024 5:14pm
garyRR
Sure, BCL. Great, honest garage. I use them all the time.
I think their hourly rate has gone up since, so it will likely be a little bit more now.
I had no symptoms, just when I put the car in for a mechanical inspection, they told me it had gone and wouldn't pass an MOT like that, so I just got it done. 2015 Range Rover Autobiography 4.4 SDV8
Post #701108 29th Sep 2024 8:43pm
