Home > In Car Electronics (L322) > Is this water ingress in my TV tuner
Cinderrella
Hi all,
Managed to take my TV tuner out and open it, does this appear to be water marks?
Post #685492 13th Feb 2024 12:10am
JMC
Yes! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #685498 13th Feb 2024 1:22am
AJGalaxy2012
It may be a long shot but, if you get some isopropyl alcohol and a toothbrush you may be able to save it. Soak the PCB with the IPA scrub it really well with the toothbrush and another soaking with IPA, allow it to dry in a warm place (on top of a radiator or airing cupboard) and try it again. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #685506 13th Feb 2024 8:53am
Cinderrella
Thanks, any idea what caused water to get in the first place?
Thinking of using isopropyl alcohol followed by leaving it on top of my dehumidifier.
Post #685507 13th Feb 2024 8:57am
AJGalaxy2012
Water ingress into that area is a common fault, search the forum for solutions.
Good luck with the IPA, it's well worth trying.
J BMW i3 Electric Car
Post #685508 13th Feb 2024 9:12am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, I don't see any scorch marks in the pictures so as long as power wasn't applied while standing water on there you may be ok.
Sure way to tell is sniff the board all over, burnt pcb / electronic components have a very distinctive smell.
IPA and a toothbrush should get rid of the stains, but even if it doesn't at lease you know it's clean, let it dry out on a radiator for a while.
Fingers crossed whan you apply power, but watch closely for any wisps of smoke or acrid smell, you don't want a fire.
Cheers
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #685517 13th Feb 2024 10:10am
Cinderrella
Hi Andy,
Nice to see you on here following your help ina previous post.
I'm not entirely convicned that cleaning it up will make the TV work again, so I've purchased another unit from fleebay, fingers crossed Whistle
Post #685518 13th Feb 2024 10:12am
