![]() | Home > Maintenance & Mods (L322) > Lowering 06 FFRR SC |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
there are companys on pistonheads and ebay that sell lowering kits..
Please see my post on RR.net for now. I've already been in touch w/ Martin (site admin) for commercial posting rights - will do an extensive post here as soon as I can.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
steve how much are you doing these systems for in sterling and what options did you end up putting on them "RANGEISM WILL NOT BE TOLERATED"
My lowering kit is about £10000000 an luckily I've managed to adapt it to cover a lot of stuff not just lowering. I'm sure you will agree it's the best tool anyone should carry in a FFRR! |
interesting read here.. http://www.rangerovers.net/forum/viewtopic.php?f=2&t=46826 |
i read that stan i just couldnt be bothered to read all the pages to find out what they ended up putting into the system and how much it would sell for in £££ "RANGEISM WILL NOT BE TOLERATED"
so there are 3 units for the diy'er , the faultmate which is very expensive, the RAC which is still in development and the one from steve....
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Does the RAC all comms adjust the height? I have not played about with mine to much yet. Reformed |
it does have the settings for this but its on the expert part which i need guidance.. |
At least this means that the device would be well suited to you. You need nearly no instructions and it is quite intuitive. ![]() Summarized very quickly (just for you ![]() - the IIDTool is the full fledged diagnostic system. At the moment the IIDTool does fault reading and clearing in all systems and has very extensive component testing/live data and programming capabilities for the EAS (better than the OEM T4 and IDS systems the dealers use actually). We will be adding numerous systems later this fall and eventually hope to have a system that is better than all other systems in its capabilities - and much easier to use/more portable/and (above all) much faster. You can clear a fault in less time than it takes to boot the computer on all the other systems. And all beta buyers will be updated for free (postage charges will have to be paid but the unit is barely more than the size and weight of a box of matches). - the EASControl is designed as a very advanced lowering/raising module. You reset the heights in the EAS ECU. And on your RR, you can reset the heights individually - that is off-road +20mm, standard -10mm, and motorway -30mm. This capability will be added for later ffrr's and the RRS/D3 this fall as well. Diagnostics is limited to fault read/clear. Same here too, btw, betas get updated for the cost of postage. Here's another short bit to read - just read my post actually. http://www.rangerovers.net/forum/viewtopic.php?f=8&t=46827 And for the lazy couch potato in you, grab a lager and look through these (in no particular order): Activation/unlock Entering/navigating the menu Fault clearing IIDTool Changing height settings EASControl (works on the IIDTool as well) ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
