Home > Technical (L322) > Central Locking Issue MY04 Car ( BMW Based) |
GRANGEROVER Member Since: 10 Feb 2022 Location: Bremen Posts: 34 |
I'm pretty sure that's something you can program with an IID tool for example. It is mentioned in the manual somewhere. Single press just unlocks the drivers door, double press unlocks every door. |
10th Feb 2024 1:49pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 821 |
yes, it works again now for the rear doors with a double press of the unlock key
10th Feb 2024 3:33pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
My 2004 car, when older, had this on rear doors, one at a time rather than both together. The linkages etc were lubricated and that solved it, so maybe look at that too, i suspect they seize up with age/non-use. Only Range Rovers since 1988 |
10th Feb 2024 9:42pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
I tend to open all doors when I want to get in the boot, to try and avoid this. Not often anyone sits in my rear seats.
11th Feb 2024 1:07pm |
