Home > Maintenance & Mods (L322) > L359 PDC module in a L322
Kuret
Canada 2011 Range Rover Supercharged 5.0 SC V8 Barolo Black
Has anyone attempted to install the LR2/L359 PDC module in a L322? I have a 2011 supercharged L322 . The modules look almost identical. The USED L322(AH42-15K866-BG) modules are $150 - 350+ the L359's (AG92-15K866-BB) are <$50. I assume they arent' interchangeable, but if they are this is a hello of a deal. I know the modules aren't vin specific.
Post #685236 10th Feb 2024 2:26am
Kuret
Bump
Post #685543 13th Feb 2024 3:05pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Does your head unit display show PDC warning indicators when reversing close to an obstruction ?
Like this :
If so, then I'm afraid that you probably do need the expensive one.
The less expensive ones are usually priced thus owing to their lesser functionality.
I believe the cheaper module will probably work.
But you'll lose the PDC related graphics when reversing.
Discovered this when following the failure of my unit, my indy swapped in one from a car without this function.
Worked as a PDC unit, but without the warning graphics.
Mine is AH42-15K866-BG
Hope this helps.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #685799 16th Feb 2024 8:51pm
Kuret
Thanks for the details on this. I don't have those red lines, I have no beeps and no function form the park assist button.
I did some preliminary digging and I found my issue. I don't have a PDC module. Does this mean that it is coded out? Do I need to code it back on when I get a new PDC or can I plug it in and it will be recognized?
Sorry for the questions I am new to this.
Post #686224 22nd Feb 2024 5:38pm
Ah, sorry matey.
I fear we have now stepped beyond the bounds of my admittedly quite meagre knowledge.
With luck someone more experienced well happen by before too long.
Post #686225 22nd Feb 2024 5:49pm
