Home > Maintenance & Mods (L322) > 2007 L322 Air Suspension Conundrum
Pistonhead99
England 2007 Range Rover Vogue TDV8 Bonatti Grey
Hello,
I’ve got a real conundrum with my air suspension front n/s. A couple of weeks ago I had a suspension error come up on the dash. Front n/s air bag had sprung a leak so had it replaced by my local Indy LR specialist. About three days later after the vehicle had stood overnight I noticed it was down a little on, yes you’ve guessed it, front n/s. Took it back to my Indy LR specialist they had it for three days but could not find an air leak anywhere in the whole system. They believe the system control unit is letting out air from the front n/s as it might be thinking it’s at the wrong height, they suspect it might be an electrical fault in the air suspension loom causing this to happen.
However it has occurred to me could it be fault with the height sensor front n/s that is causing the deflation.
What do people think? Any ideas? 2007 Range Rover L322 3.6 TDV8
2008 Range Rover Sport SE 2.7 TDV6
2005 Range Rover Sport S 2.7 TDV6
2002 Discovery 2 TD5
1999 Freelander 1
Post #685210 9th Feb 2024 5:29pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Hi
I was having similar issues with my rear near side ,after trying several things it turned out to be the rubber seals in the valve blocks.best way to find out if you have a air leak is to put it into off road mode pull the relay fuse and see what it looks like next morning
Post #685237 10th Feb 2024 3:59am
Pistonhead99
OK thanks 2007 Range Rover L322 3.6 TDV8
1999 Freelander 1
Post #685265 10th Feb 2024 2:06pm
