![]() | Home > Technical (L322) > water in fuel sensor |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 905 ![]() ![]() ![]() |
This is good to know, do you have a source for the parts please, and part numbers - thx |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
On my 3.6TDV8 random water in fuel warnings, new filter and diagnostic by main dealers says no water but need new housing for $$$$$. I just unplugged the sensor multiplug with no issues or warnings so job done. 2007 TDV8 VSE
Ryanc Member Since: 16 Feb 2025 Location: Kent Posts: 6 ![]() ![]() ![]() |
Hi misfire84 - did you use a particular type of resistor? I’m having an ongoing yellow triangle / water in fuel code and it’s driving me insane after changing the wif sensor and filter etc … wanted to try your fix before having to pay out £££££ 😭
The Ford Transit Housing is £30 quid, just remove the harness, its all you need
Thanks, but I have brought two genuine ones one used one new and they haven’t solved the yellow restricted performance issue |
I don't think you will get a response from misfire84 as he has not posted for here for over a year, and he did not reply to me asking him about his resistor method either, good luck sorting it, for most of us it was simply the harness that needed replacing. |
Ryanc --- as misfire84 is no longer responding, the resistor trick from my notes is the following : Place a 690 ohm resistor between signal and ground and 12k between signal and sensor power on the wires going back to the ECU - let us know how you get on ![]() |
