Home > Maintenance & Mods (L405) > 2 Tonne or 3 Tonne lifting capacity & stands?
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
I am having a mare this week, I have a couple of different related posts on the go and I it is like 1 step forward, 2 steps back! So it turns out that the trolley jack that I have cannot lift my L405. It is a fairly small jack and I have no idea what the lifting capacity of it actually is so I am going to have to buy a new one.
Question, for a 2019 L405 what minimum weight capacity and what maximum lift height should I be looking for in a trolley jack and axle stands? Do I need a trolley jack or would a bottle jack be just as good?
I am led to believe that the L405 is a little lighter than the L322 due to the aluminium body, is that correct? So a jack that can be used on an L322 should be more than adequate for an L405?
As always many thanks for any and all guidance. Thumbs Up
Post #684331 30th Jan 2024 5:34pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I cant really answer the question properly, but I had a 2T trolley jack bend and buckle under my L322.
Probably just a bad jack, but I bought a 3T SGS trolley jack which makes light work of lifting it.
Bottle jack are good, I just worry about the small footprint, as these cars do move during the actual lifting.
Post #684335 30th Jan 2024 6:20pm
V8 Bob
Get a 3 tonne one…your life is worth it! Same with axle stands get 3 tonne ones remember the old adage better safe than sorry!
In theory a 2 tonne one will lift a FFRR as you are not lifting the full weight but a good safety margin is always the best policy. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #684337 30th Jan 2024 6:29pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I have a 4T two post full rise lift. If you have the space then a 2 post or scissor lift is the safe and comfortable way to go and most RR owners can afford the £2k to £5k install cost. That's only about 3 to 5 RR dealer services.
Post #684342 30th Jan 2024 7:13pm
Gremlin500
3Te.
Remember, the 3Te axle stands will probs have a much taller max height. I have both, and my 2Te ones simply can’t reach parts of the fullfat.
As V8_Bob says, a 3Te trolley jack has a bigger more stable footprint, and will roll itself under the point of load, bottle jacks are way more likely to topple.
Don’t take any chances!!! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #684344 30th Jan 2024 7:27pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, I have 2 trolley jacks, a 3 tonne smallish one that I keep in the car and a full size 5 tonne high lift one with a removeable cross beam attachment for major works, get a quality one with a wide base for added stability.
Axle stands I have 4 x 5 tonne Drapers, with the quick release locks.
Don't use axle stands extended more than 70% available height unless on very sturdy and level ground. Either get a taller set or like I do mount on 12" x 10" x 6" rail sleeper blocks for support. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #684365 30th Jan 2024 9:11pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
I agree with the guys. Always go bigger. We buy these big heavy cars, always better to have bigger kit that is over spec rather than on spec. 3-6 Tonne axle stands at a minimum and 3-5 tonne Jack. If you havent seen the below video by project farm although he is testing US branded axle stands its something everyone should watch.
?feature=shared
Am I the only person who also puts the wheels under the car even when on stands? Current yokes
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #684404 31st Jan 2024 10:12am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I have 2, 3ton bottle jacks, as mentioned above using a single bottle jack can be a bit too interesting, the vehicle has to be lifted quite high and leans alarmingly on the small footprint. Using 2 jacks makes it more to my liking, but a 3 ton trolley jack is definitely the way to go. SGS regularly do bundled jack & stand deals, good quality kit IMO.
Will
Post #684427 31st Jan 2024 1:43pm
philip1972
Not only you, I always put the wheels under too!
Post #684428 31st Jan 2024 2:23pm
Merchy
Use a 3 tonne trolley jack, and then minimum of two 3 tonne axle stands. If I take off both front wheels, I use three axle stands.
One important thing to remember is think about the surface of the drive or garage etc, thin tarmac can give way, best to have some wood or steel to spread the weight over a larger area.
When using any ratchet style axle stands, always tie the ratchet release handle / arm just in case an accidental blow from a hammer of slipped large lever bar hits the handle, unlikely but possible !
Post #684433 31st Jan 2024 4:29pm
ABAB
I’ve used this jack successfully https://www.costco.co.uk/Tyres-Automotive/...U/p/254971 2016 SDV8 AB
Post #684502 1st Feb 2024 9:47am
RDR
I have two decent 3ton trolley jacks in the garage and a 2 ton which feels bit sketchy for a Land Rover . I also a have a power built jack which I find works brilliant
 MY23 PHEV HSE
MY19 Disco 5 HSE - gone
My16 Disco 4 HSE LUXURY - gone
My12 Disco 4 HSE - gone
MY05 Disco 3 S - gone but not forgotten
Post #684541 1st Feb 2024 3:38pm
Fla
RDR
I like that bottle jack axle stand hybrid, looks very strong. Were those expensive? It reminds me of a trailer jack a colleague of mine invented. Instead of a stupid jokey wheel on a heavy trailer he made a unit for jacking it with a bottle jack that replaces the jockey wheel. I like things combined with bottle jacks Smile Current yokes
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #684555 1st Feb 2024 5:34pm
RDR
It is good, nice and sturdy and lifts very high the ratchet clicks in as you go up which is great and to lower you just bump it up a bit release the safety and lower on the bottle jack.
£90 on Amazon
https://amzn.eu/d/6pSuCub MY23 PHEV HSE
Post #684557 1st Feb 2024 5:50pm
Fla
Thanks for the link RDR, that was very good of you. Ill definitely be adding these to the workshop before I get my 2 post lift. Current yokes
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #684558 1st Feb 2024 6:06pm
