Home > My Range Rover > My 2013 TDV8 Autobiography struggle |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2784 |
I've had my L322 for over 2 years and have never opened the sunroof for that very reason. 2012 TDV8 Vogue (L322) |
28th Jan 2024 10:35am |
jamiej Member Since: 01 Dec 2023 Location: Surrey Posts: 35 |
Oh mate... You opened the sunroof?!
28th Jan 2024 7:22pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7647 |
I hardly ever drive mine with it shut….. 🤔🤣 2011 Range Rover Vogue SE 4.4 TDV8
28th Jan 2024 7:35pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16187 |
Pull down the roof panel and close it manually... Im sure there's an Allan key hole in the bottom of the motor for just this reason...
28th Jan 2024 7:47pm |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 28 |
No allen key hole on the sunroof motor on the L405. It was shut by temporarily swapping the sunroof motor and the blind motors over.
8th Feb 2024 10:13pm |
Having done an oil change, I can say that the vacuum oil drain tube is a game changer. I’ve seen these on boats, where there is no space below the sump, as the engine is mounted as low as possible, so vacuum drain is required.
10th Feb 2024 6:27pm |
Coolant expansion tank changed this week. No more low coolant level warning! |
20th Feb 2024 10:54pm |
Changed a non-genuine tail lamp for a genuine one. Now they both match!. Will it improve the radio reception? I doubt it... |
12th Mar 2024 11:34pm |
Well, I've only driven the car once since, but the DAB reception does seem to be better. Not as good as some other cars, but better than it was before. |
23rd Mar 2024 8:39pm |
Bit the bullet and paid for a genuine luggage divider/dog guard. Fitted it today. It's well made and fits nicely. Pricy, but you can see why. |
23rd Mar 2024 8:40pm |
