Home > My Range Rover > My 2013 TDV8 Autobiography struggle
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
For the last 6 years I have been the owner of a Discovery 3. Ownership has been a struggle, and the towbar now has some play in it, so it's the end of its towing days. However I need something for towing.
Of course, you'd have to be a fool to buy another Land Rover product after feeling like it brought you more grief than it was worth! But having looked at the available alternatives, I kept thinking that I would like a Range Rover, at least for a bit. I guess it's like Stockholm Syndrome. It makes no sense, but you do it anyway.
So... I bought the cheapest Range Rover L405 Autobiography with a towbar on AutoTrader.
When I looked at the car, it was in a good condition for the age (it's a 2013). But of course, there will be faults.
So I drove it 180 miles home, and it drove quite nicely. (I had test driven some other cars, which had expensive sounding things like clonking suspension). Managed 41 mpg before I got to the petrol station. Then, once at home, in the name of experimentation, I decided to open the sunroof. Now the sunroof won't close, and it appears to be dead. It's not even trying to move, though the blind still works. Censored
Start as you mean to go on! Big Cry Laughing
Post #684065 27th Jan 2024 9:54pm
JayGee
I've had my L322 for over 2 years and have never opened the sunroof for that very reason. 2012 TDV8 Vogue (L322)
Post #684089 28th Jan 2024 10:35am
jamiej
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Oh mate... You opened the sunroof?!
Is your middle name "danger"
Post #684133 28th Jan 2024 7:22pm
mjdronfield
I hardly ever drive mine with it shut….. 🤔🤣 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #684134 28th Jan 2024 7:35pm
Pull down the roof panel and close it manually... Im sure there's an Allan key hole in the bottom of the motor for just this reason...
If you still have your Disco? Take it into a main dealer and ask them to look at the towbar. If its worn the rear chassis cross member, JLR was paying to replace the crossmember and fit a genuine heavy duty towbar... I think its still live... Thumbs Up
Post #684138 28th Jan 2024 7:47pm
hmallett
No allen key hole on the sunroof motor on the L405. It was shut by temporarily swapping the sunroof motor and the blind motors over.
Surely JLR aren't doing recalls on 16 year old cars?! I'll check over on the disco3 forum.
So far on the RR I've changed oil, pollen and air filters, with an oil change, and changed the coolant level sensor. Might need the coolant expansion bottle replacing though.
Post #685135 8th Feb 2024 10:13pm
hmallett
Having done an oil change, I can say that the vacuum oil drain tube is a game changer. I’ve seen these on boats, where there is no space below the sump, as the engine is mounted as low as possible, so vacuum drain is required.
Last time I did a oil drain via the supply (20 years ago), it was in a garage with a concrete floor, and being on my back, with hot oil running up my arm was horrible.
So given that this time I did the oil change outside, on gravel, while it was raining, the vacuum oil change prevented me feeling very, very sad!
Post #685279 10th Feb 2024 6:27pm
hmallett
Coolant expansion tank changed this week. No more low coolant level warning!
Post #686107 20th Feb 2024 10:54pm
hmallett
Changed a non-genuine tail lamp for a genuine one. Now they both match!. Will it improve the radio reception? I doubt it...
Post #687921 12th Mar 2024 11:34pm
hmallett
Well, I've only driven the car once since, but the DAB reception does seem to be better. Not as good as some other cars, but better than it was before.
Post #688826 23rd Mar 2024 8:39pm
hmallett
Bit the bullet and paid for a genuine luggage divider/dog guard. Fitted it today. It's well made and fits nicely. Pricy, but you can see why.
Post #688827 23rd Mar 2024 8:40pm
