Home > Technical (L405) > DIY Oil change on SDV8 reveals underfilled or burning lots |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1225 |
Are you using a vacuum pump or draining from the drain plug? 2018 SE SDV8 4.4 Byron Blue |
27th Jan 2024 1:00pm |
Geo Member Since: 04 Apr 2023 Location: South East Posts: 16 |
Drained down from the sump plug. |
27th Jan 2024 1:02pm |
Check to see if there is a blockage, could be a lot of carbon gunge etc do you have a boroscope?
27th Jan 2024 1:28pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 333 |
Wow, that is a lot of oil. Unlikely to have used or leaked 6 litres I would have thought. I regularly check the oil in my cars so that I can establish how much is being used (if any) and how often it needs topping up.
27th Jan 2024 1:45pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1141 |
3 litres? Cant be. Does the oil level sensor work now? overfinch modified |
27th Jan 2024 5:05pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2491 |
Did you remove and drain from the turbo return reservoir drain plug? |
27th Jan 2024 7:30pm |
Didn’t drain down turbo reservoir. How much would be in there?
28th Jan 2024 10:09pm |
That you put in 9.2L to get to the correct level shows that you didn't just drain from the turbo reservoir drain plug. |
28th Jan 2024 10:21pm |
Do you have oil in the cooling system? 2018 SE SDV8 4.4 Byron Blue |
28th Jan 2024 10:22pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1219 |
Check the oil filter drain leaf spring is on it's post and not loose in the bottom of the filter housing. |
28th Jan 2024 10:27pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
I can't believe that you weren't having overheating issues or low oil pressure with only 3lt of oil in the system.
28th Jan 2024 10:28pm |
No oil in the cooling system.
29th Jan 2024 6:55am |
So all the basic possibles covered, lets hope its not the turbo's seals leaking etc burning the oil off.
29th Jan 2024 8:56am |
