Home > Technical (L405) > DIY Oil change on SDV8 reveals underfilled or burning lots
Geo
Censored
I'd appreciate everyone's thoughts on this.
SDV8. Full Land Rover SH until 2023.
Last dealership oil cooler work & oil change was 2023
Now the warranty has lapsed I decided to start maintenance. When expecting 9.4litres ish to drain from the sump I only got 3litres! Big Cry
Oil was warm and left to drain. (No significant engine oil leaks to speak of).
No low oil warnings on dash prior.
Things spring to mind.
Dealer forgot to refill after oil cooler work in 2023? or
No prior warning of low oil makes me wonder if the oil level sensor had already packed up in 2023 and the dealer thought they had refilled it? Or
Engine is burning a lot of oil and coupled to the sensor failure its not been noticed
Bottom line 13,000 miles with potentially just 3 litres of oil! (Should have been a 9.4L)
I will of course discuss this with the dealership who has always looked after my car and I have a good relationship with, but wanted to get some opinions on potential damage to the engine and how others would react to this.
Thanks all
Post #684017 27th Jan 2024 11:22am
Kot
Are you using a vacuum pump or draining from the drain plug? 2018 SE SDV8 4.4 Byron Blue
Post #684023 27th Jan 2024 1:00pm
Geo
Drained down from the sump plug.
Post #684024 27th Jan 2024 1:02pm
Kot
Check to see if there is a blockage, could be a lot of carbon gunge etc do you have a boroscope?
Did you loosen oil filter? 2018 SE SDV8 4.4 Byron Blue
Post #684027 27th Jan 2024 1:28pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Wow, that is a lot of oil. Unlikely to have used or leaked 6 litres I would have thought. I regularly check the oil in my cars so that I can establish how much is being used (if any) and how often it needs topping up.
That would have avoided your situation (I know, hindsight and all that). If you start doing that now at least you’ll know if it had used that amount of oil and it will give you some ammo against the dealer.
I would take it up with the dealer to start with, in case it has done some damage.
Post #684030 27th Jan 2024 1:45pm
caymanblack
3 litres? Cant be. Does the oil level sensor work now? overfinch modified
Post #684048 27th Jan 2024 5:05pm
GraemeS
Did you remove and drain from the turbo return reservoir drain plug?
Post #684062 27th Jan 2024 7:30pm
Geo
Didn’t drain down turbo reservoir. How much would be in there?
Re: checking oil, hasn’t ever used any oil between services, so either something dramatic has changed and it’s burning loads or it never had 9.4l in there.
Oil level sensor works and on refill (done in stages) it filled with nearly 9.2L.
The odd thing is there was never a low oil pressure warning, perhaps 3L is enough not to trigger this light? Does anyone know?
Post #684162 28th Jan 2024 10:09pm
GraemeS
That you put in 9.2L to get to the correct level shows that you didn't just drain from the turbo reservoir drain plug.
Post #684166 28th Jan 2024 10:21pm
Kot
Do you have oil in the cooling system? 2018 SE SDV8 4.4 Byron Blue
Post #684167 28th Jan 2024 10:22pm
kevinp
Check the oil filter drain leaf spring is on it's post and not loose in the bottom of the filter housing.
Post #684168 28th Jan 2024 10:27pm
dingg1
I can't believe that you weren't having overheating issues or low oil pressure with only 3lt of oil in the system.
Something is awry here.
Post #684169 28th Jan 2024 10:28pm
Geo
No oil in the cooling system.
No overheating. The spring was present and correct on the perch in the filter housing.
Post #684183 29th Jan 2024 6:55am
Kot
So all the basic possibles covered, lets hope its not the turbo's seals leaking etc burning the oil off.
https://glenrands.co.uk/2020/11/26/know-yo...%20idling. 2018 SE SDV8 4.4 Byron Blue
Post #684191 29th Jan 2024 8:56am
