Home > In Car Electronics (L322) > Pandora alarm/gps system
Maccaa
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
I am thinking of having one of these systems installed. I know they are expensive but probably not compared to insurance renewal after a theft Sad
Has anyone had a system fitted and can confirm the pre heat still works when alarmed?
I would imagine everything would be fine seeing as the system can remote start and still be armed but just asking.
Thanks
maccaa Current FF Westminster 4.4 V8
Post #684248 29th Jan 2024 8:25pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hate to say this but car alarms less than useless, theives just set them off constantly so you and the neighbours get so upset you're forced to disable it, they then come along, give it a nudge, doesn't go off, they're in and away.
Same as trackers, they just shove the car in a steel container, or copper lined car transporter, it can chirp all it likes, signal is not getting out.
Once in Albanianazikistan, thieves just start ripping it apart till they find it. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #684249 29th Jan 2024 8:40pm
