Home > Wheels & Tyres > Tpms compatibility
jjames
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Tpms compatibility
Hi guys.
New to ffrr here having just bought a 64 AB 4.4. It came with 23" overfinch wheels which are just not suitable for our local potholes. I'd like to change them for a set 21" or 22". I've found a later set but will the tpms valves on 2022 wheels be compatible with my 64 reg?
Many thanks for your help in advance.
J
Post #683450 21st Jan 2024 6:23pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
If they are from an L405 with the metal valve stems then they swap in as ‘plug and play’ without any issues. If they are the newer type that are now used by JLR with the rubber valve stems then they still work but you need to code them to your car.
Post #683452 21st Jan 2024 6:26pm
jjames
Thank you. That's really informative. Do you happen to know a date for the change? I suppose I can always look at the stem!
Is the coding for the newer type something that could be done by myself with an icarsoft or would I need to take it to LR?
Thanks again
Post #683455 21st Jan 2024 6:47pm
Alex1976
I think the change occurred in line with the change from L405 to L460 but not 100% certain on that.
You should be able to reprogram them yourself with a TPMs reader/coder not sure if icarsoft does TPMs coding though.
Post #683464 21st Jan 2024 7:48pm
jjames
Thank you. I'll go and investigate
Cheers
Post #683467 21st Jan 2024 8:01pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
@jjames - Did you by any chance buy your car from Barnet?
I was looking at a car there which also had 23” alloys, and they would have been my first candidate for changing.
Post #683686 23rd Jan 2024 6:12pm
jjames
I did! I'm sorry if I beat you to that one. Those wheels are just too big! They dont look too gangster but are a bit of a liability where I live.
Post #683691 23rd Jan 2024 6:26pm
