![]() | Home > Wheels & Tyres > Tpms compatibility |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 86 ![]() ![]() ![]() |
If they are from an L405 with the metal valve stems then they swap in as ‘plug and play’ without any issues. If they are the newer type that are now used by JLR with the rubber valve stems then they still work but you need to code them to your car. |
jjames Member Since: 20 Jan 2024 Location: Scotland Posts: 10 ![]() ![]() ![]() |
Thank you. That's really informative. Do you happen to know a date for the change? I suppose I can always look at the stem!
I think the change occurred in line with the change from L405 to L460 but not 100% certain on that.
Thank you. I'll go and investigate
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 41 ![]() ![]() ![]() |
@jjames - Did you by any chance buy your car from Barnet?
I did! I'm sorry if I beat you to that one. Those wheels are just too big! They dont look too gangster but are a bit of a liability where I live. |
