Home > Technical (L322) > Some odd symptoms- possibly FSR?
Kent_newbie
Hi all,
I have a '57 plate 3.6 TDV8 that, touch wood, has been fabulous.
Recently noticed some oddities, and after some googling wonder if it could be the final stage resistor - and would appreciate your thoughts.
The symptoms:
1) there is a fan (roughly behind dash, but in engine bay) staying on for fair few minutes after turning off engine, even if its been on only for 30 seconds.
2) auto climate control - when trying to make car hot, I can hear fans blasting at high speed, but air doesn't come out front facing vents. However, if I manually select those vents with the buttons air comes out fine.
3) possibly some battery drain going on.
Is it likely to be the FSR, do you think?
Thanks!
Tony
Post #683181 19th Jan 2024 10:53am
V8 Bob
When my FSR failed the heater fan was stuck on didn’t knock off at all even with engine off and locked. Yiuu couldn’t change fan speed either. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #683186 19th Jan 2024 11:25am
Kent_newbie
hmmm, yes that does sound a different sympton
Post #683187 19th Jan 2024 11:35am
kevinp
Could it be the FBH winding down after being activated because of the cold weather?
Post #683196 19th Jan 2024 1:36pm
Kent_newbie
Thanks for the thought...that's a good point. Never noticed it before, but feasible I guess.
I could never get the FBH working on the timer, assume it didn't work at all. Car does seem to heat up pretty quickly though.
Any ideas if that would be linked to oddities in the cabin fans?
Post #683221 19th Jan 2024 4:07pm
