Home > Technical (L322) > Engine overheating |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3196 |
I assume you are loosing coolant ? so the first thing to do is find out where it's leaking from. 2012 TDV8 Vogue (L322) |
14th Jan 2024 1:09pm |
timse Member Since: 06 Dec 2019 Location: Farnborough Posts: 37 |
Only from the expansion cap when it’s over heating. |
14th Jan 2024 1:16pm |
Thermostat or waterpump failure would be the first suspects. 2012 TDV8 Vogue (L322) |
14th Jan 2024 1:18pm |
Would either show up on GAP. Not seeing any failures that might point to cooling 😞. Water pump is less than 6 months old as well. |
14th Jan 2024 1:30pm |
Neither will show on the gap as they are not equiped with sensors. If the waterpump is new ( Genuine?) then you are looking at the thermostat or some other coolant flow blockage. Why was the pump replaced BTW? Is it running smoothly and not throwing white steam out of the exhaust? Does it start smoothly in the morning. HC vapor test on the coolant would be a garage job to test for headgasket integrity. 2012 TDV8 Vogue (L322) |
14th Jan 2024 1:34pm |
Let her cool down and attempted the one junction I needed to get down. Nearly made it 😞.
14th Jan 2024 2:49pm |
Any idea on which one is the coolant pump fuse so I can check.
14th Jan 2024 3:05pm |
So, resided myself to having to start looking for where the issue was since getting it home just about.
15th Jan 2024 1:59pm |
but I'd test it some more on local roads. 2012 TDV8 Vogue (L322) |
15th Jan 2024 2:31pm |
