Home > My Range Rover > New to forum and new car
Charles H
United Kingdom 2007 Range Rover Vogue SE TDV8 Zambezi Silver
What a great site this is, I have recently bought a L322 TDV8 Vogue SE in siler with a black interior. Whilst the turbos have been done, and the suspension all works as it should, it does have its niggles which with the wealth of information on here I am starting to address. No doubt I will be asking some stupid questions in due course, mainly to do with electrics, which is my nemesis. So why then did I buy a RR? Because I wanted to and I will have to learn!
Post #682674 14th Jan 2024 11:41am
JayGee
Thumbs Up 2012 TDV8 Vogue (L322)
Post #682676 14th Jan 2024 11:48am
DrRob
Welcome!
Change all the fluids throughout as a priority. Both gearboxes, both diffs, coolant, brake fluid, PAS fluid and engine oil
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #682679 14th Jan 2024 12:46pm
JayGee
If you are new to these cars it's well worth paying a specialist to give it a detailed inspection so you know what's what in terms of potential jobs. They may well give you a list as long as your arm but don't be alarmed as these cars can be run quite well as running repairs/ projects and you can often take your time to work through them. 2012 TDV8 Vogue (L322)
Post #682690 14th Jan 2024 1:41pm
Charles H
Thank you both. Fortunately I have the receipts for engine oil and filter change under 2000 miles ago when the turbos were changed, the gearbox oil and filter 10000 miles ago and diff oils 8000 miles ago, so do not have too many concerns with those. I will check the power steering and brake fluids, but suspect they are ok since the engine was removed for the turbos to be fitted. Getting an independent health check done is a great idea. I am aware of a few faults already, but with the help on threads on this site, I am working my way through them. GPS receiver already successfully replaced, and the single solenoid heater valve on order to hopefully get heat inside! Charles Harrison
Folkestone
Cherry Red Mk1 Triumph 2000 Rally Car
Mallard Blue Triumph 2.5PI
Sapphire Blue Triumph GT6 Mk3
Vermillion Red Triumph Spitfire 1500
Pimento Red Triumph TR6
Inky Blue VW Passat B5.5
Arctic Blue Jaguar XJ40
Zermatt Silver Range Rover Vogue SE 3.6 TDV8
Post #682774 15th Jan 2024 1:02pm
Charles H
Single solenoid valve replaced. I now have heat Very Happy Charles Harrison
Folkestone
Post #682980 17th Jan 2024 11:29am
Stuart-
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Welcome to the site, Charles.
I never had an independent inspection at all on any of mine. I just used common sense and the good folk of the forum here. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #683036 17th Jan 2024 9:16pm
