Home > My Range Rover > New to forum and new car |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3201 |
2012 TDV8 Vogue (L322) |
14th Jan 2024 11:48am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Welcome!
14th Jan 2024 12:46pm |
If you are new to these cars it's well worth paying a specialist to give it a detailed inspection so you know what's what in terms of potential jobs. They may well give you a list as long as your arm but don't be alarmed as these cars can be run quite well as running repairs/ projects and you can often take your time to work through them. 2012 TDV8 Vogue (L322) |
14th Jan 2024 1:41pm |
Charles H Member Since: 13 Jan 2024 Location: Folkestone Posts: 8 |
Thank you both. Fortunately I have the receipts for engine oil and filter change under 2000 miles ago when the turbos were changed, the gearbox oil and filter 10000 miles ago and diff oils 8000 miles ago, so do not have too many concerns with those. I will check the power steering and brake fluids, but suspect they are ok since the engine was removed for the turbos to be fitted. Getting an independent health check done is a great idea. I am aware of a few faults already, but with the help on threads on this site, I am working my way through them. GPS receiver already successfully replaced, and the single solenoid heater valve on order to hopefully get heat inside! Charles Harrison
15th Jan 2024 1:02pm |
Single solenoid valve replaced. I now have heat Charles Harrison
17th Jan 2024 11:29am |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 301 |
Welcome to the site, Charles.
17th Jan 2024 9:16pm |
