Home > Technical (L322) > Turn key won't Turn over |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Ignition switch? John
8th Jan 2024 5:00pm |
v3mmtrangerover Member Since: 29 Jan 2020 Location: sunderland Posts: 30 |
Haven't changed that out yet as it does work most the time 😕 think that's me next port of call just wanted to see if anyone had had the same issue |
8th Jan 2024 5:02pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1180 |
I had exactly the same issue, only difference was that my ignition key is mounted in the centre console not the dash, fitting a new switch ( plastic / electrical section only )solved the problem.
8th Jan 2024 8:01pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 804 |
Thanks, MY04 Petrol V8 is centre dash for the key, I will take out the plastic ignition switch and clean all the contacts, as it has been a bit tempermental over the winter months. |
8th Jan 2024 10:50pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
Ignition switch it is I change mine a few years back its pretty simple to swop out I even took the old switch apart cleaned it and put it somewhere safe never to be seen again.
9th Jan 2024 11:09am |
For anyone changing the centre mounted ignition switch, mazza7282 posted this excellent 'How to' guide with photos, makes the job quite easy -
9th Jan 2024 11:25am |
