![]() | Home > Technical (L322) > Turn key won't Turn over |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
Ignition switch? John
v3mmtrangerover Member Since: 29 Jan 2020 Location: sunderland Posts: 30 ![]() ![]() ![]() |
Haven't changed that out yet as it does work most the time 😕 think that's me next port of call just wanted to see if anyone had had the same issue |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
I had exactly the same issue, only difference was that my ignition key is mounted in the centre console not the dash, fitting a new switch ( plastic / electrical section only )solved the problem.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 856 ![]() ![]() ![]() |
Thanks, MY04 Petrol V8 is centre dash for the key, I will take out the plastic ignition switch and clean all the contacts, as it has been a bit tempermental over the winter months. |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 935 ![]() ![]() |
Ignition switch it is I change mine a few years back its pretty simple to swop out I even took the old switch apart cleaned it and put it somewhere safe never to be seen again.
For anyone changing the centre mounted ignition switch, mazza7282 posted this excellent 'How to' guide with photos, makes the job quite easy - |
