Home > Technical (L322) > 2008 TDV8 Bluetooth Module Repair
GeoffWestWales
Hi all, Happy New Year, we recently bought a 2008 TDV8 3.6 L322 and loving it, working my way through some small problems, the Sat Nav Screen is just blue and get no phone module fitted and cant see any signal when I activate the Bluetooth on my phone so suspect the Bluetooth Module may be broken, is there anyone that repairs them?, if not and I get a used one will it need coding to the car, I have the Icarsoft LR3 scanner not sure if that can do it?
Are they easy enough to remove the connectors?
Post #681989 6th Jan 2024 2:53pm
garyRR
If it's the old Nokia Bluetooth unit, they're well known to give up. You can swap it with the much more reliable Bluetooth unit from 2010 onwards cars. 2015 Range Rover Autobiography 4.4 SDV8
Post #682001 6th Jan 2024 4:12pm
GeoffWestWales
Thanks for the tip GaryRR, will have a look on eBay and you are correct mine is the Nokia unit
Post #682010 6th Jan 2024 4:46pm
