Home > In Car Electronics (L322) > Digital TV Tuner |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 |
Reformed,
18th Aug 2011 8:29pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
I have one of these;
18th Aug 2011 9:28pm |
Thank you Reformed for the info. Will be looking into this soon.
19th Aug 2011 5:52pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Has anyone thought about one of these babys? http://www.eonon.com/Others/Others/V0012T.html
28th Aug 2011 8:42pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Any thoughts on how you would install in an 06 SE with rear entertainment? Any help would be most apreciated as my kids would love abit of freeview! |
29th Aug 2011 10:17pm |
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 |
26th Sep 2011 4:26pm |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 |
Afternoon,
9th Oct 2011 1:30pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
the easiest thing is to buy a genuine digital tuner and it is plug and play then with nothing else to change.
9th Oct 2011 5:30pm |
Thanks for the prompt response, do you have a part number?
9th Oct 2011 6:26pm |
http://www.fullfatrr.com/forum/topic1868-45.html
9th Oct 2011 6:47pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6735 |
£300 is VERY cheap!
9th Oct 2011 6:52pm |
Stu,
9th Oct 2011 7:01pm |
Stu, how is the reception with the oem digital tuner You bought from wiggs. As its a plug and play your using the Original car analoge areial i assume. Iv bought the same freeview as reformed has got but the areial needs upgrading As the picture is bad when your on The move. if i cant figure Out how to connect to original car areial then i may Also buy a booster also like his. Range rover td6 54 reg touch screen |
10th Oct 2011 7:47pm |
