![]() | Home > In Car Electronics (L322) > Digital TV Tuner |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
Reformed,
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
I have one of these;
Thank you Reformed for the info. Will be looking into this soon.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Has anyone thought about one of these babys? http://www.eonon.com/Others/Others/V0012T.html
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Any thoughts on how you would install in an 06 SE with rear entertainment? Any help would be most apreciated as my kids would love abit of freeview! |
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 ![]() ![]() ![]() |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 ![]() ![]() ![]() |
Afternoon,
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
the easiest thing is to buy a genuine digital tuner and it is plug and play then with nothing else to change.
Thanks for the prompt response, do you have a part number?
http://www.fullfatrr.com/forum/topic1868-45.html
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6768 ![]() ![]() ![]() |
£300 is VERY cheap!
Stu,
Stu, how is the reception with the oem digital tuner You bought from wiggs. As its a plug and play your using the Original car analoge areial i assume. Iv bought the same freeview as reformed has got but the areial needs upgrading As the picture is bad when your on The move. if i cant figure Out how to connect to original car areial then i may Also buy a booster also like his. Range rover td6 54 reg touch screen |
