Home > Maintenance & Mods (L405) > L405 Service Schedule SDV8
Cinderrella
Hello All,
Newbie here - I am very close to purchase my dream car... It is a RR Vogue L405 4.4SDV8
I wish I could have gone for the Vogue SE however, I've really struggled to find one within my budget.
I am hoping you can help with understanding the service schedule on a SDV8 (2014) the person I am buying off tells me it has JLR to 85k miles and then all independent from there - I have the following:
Ensure differential oil has been changed (if not, I'll do this if so how much would this cost please?)
Transfer box oil change (if not, I'll do this if so how much would this cost please?)
Are there any belts / pulleys etc I need to ensure have been done / changed? The car is on 104k - it is my first RR and I am hoping to wrap her a lovely pink colour too!
Look forward to hearing from you all xx
P.s. Just like all of you, I've worked far too hard to afford a luxury car like this, would you say if I'm going for a RR then to do it properly and ONLY get a Vogue SE or is Vogue okay?
Post #681750 3rd Jan 2024 12:54am
Maher2023
United Kingdom 2018 Range Rover Autobiography SDV8 Fuji White
Hi, buying a FF Range Rover..you will be stepping into luxury and it comes as standard…but then it just depends on how much luxury/convenience feature do you want.
As the higher you go in range: Vogue, Vogue SE, Autobiography etc
You will get more n more convenience/comfort and luxury features added but they do come at a price.
But the age/mileage range you are looking at I don’t think the price difference will be massive.
In terms of service costs…I’m sure more knowledgeable people on this forum will guide you.
Post #681760 3rd Jan 2024 8:23am
Kot
You can input your VIN here https://osh.landrover.com
2014 then it should have done 108 months service (144000 miles)
Which is
Replace interior air filter.
Renew engine oil and filter.
Renew brake fluid.
Drain fuel filter water trap.
Replace front accessory drive belt.
Renew transmission oil and filter.
Renew front differential oil.
Renew rear non-locking differential oil (if fitted).
And the year before is 96 months
Replace the air cleaner element.
Replace fuel filter element.
Renew transfer box oil.
Renew rear locking differential oil (if fitted).
If you do short runs then you may need to renew oil more frequently than yearly/ 12k miles.
Find a local Indy garage that has experience with FFRR.
Fit a Ghost, visual deterrents and a good tracker as its open season with the tea leafs etc and get Insurance quotes now Rolling with laughter as you may then change your mind. 2018 SE SDV8 4.4 Byron Blue
Post #681794 3rd Jan 2024 4:11pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
For the transfer box, diffs and gearbox, get the flushed and refilled by Ian Bodsworth (Bodsy) 07770 638023. He is very reasonable price wise.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #681795 3rd Jan 2024 4:13pm
Cinderrella
Hello @kot I have had three insurance quotes
£470
£490
£520
Is that too expensive?
Post #681836 4th Jan 2024 8:01am
Kot
No! snap their hands off Rolling with laughter
Several members have had treble and more quotes. 2018 SE SDV8 4.4 Byron Blue
Post #681840 4th Jan 2024 8:57am
Cinderrella
Thanks, I think you assumed I was a 18 year old female living in London. Thankfully, our rural village has not had a car theft probably since the 70's!
Post #681841 4th Jan 2024 8:59am
Kot
I never assume anything, the Land Rover marque is experiencing lots of thefts hence Insurance is starting to sky rocket coming your way soon.
So dont rely on the RR factory immobiliser or the factory tracker, and disable keyless entry. 2018 SE SDV8 4.4 Byron Blue
Post #681844 4th Jan 2024 9:27am
