Home > Technical (L322) > jacking points and suspension
E18RLY
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
im going to have a bash at finding me annoying noking noise today, ive got a 5 ton bottle jack and 3 ton axle stands.
this is the first time ive jack up the rr what do i do?
im assuming jack up from diff or main chassie ?
what do i do with suspension gearbox ect ?
im thinking leave it in park dont touch low range and lock suspension but could be expensive if im wrong.
cheers scott
Post #74304 31st Jul 2011 7:14am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
On the toolbar under the FFRR website banner there is a section called "Wiki" - have you looked in there as there for the info? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #74311 31st Jul 2011 7:56am
mzplcg
FWIW, I follow the basic rules of drop suspension into access height to relieve the pressure in the airbags. Disconnect battery so the car doesn't try to self level. Jack under the suspension arms and put axle stands under the main jacking points.
Also worth noting that is you ever undertake work on the EPB it's a very good idea to disconnect the battery. You really don't want that setting itself when you have fingers in the mechanisms Wink
Dom.
Post #74315 31st Jul 2011 8:31am
SteveMFr
Site Sponsor
Go to the wiki, find the download link to the RAVE and read before starting. This is not a 1971 Ford Cortina. Even disconnecting the battery can become an expensive mistake if you don't follow the proper procedure.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #74329 31st Jul 2011 12:21pm
E18RLY
Cheers al check it out now thanks for the advice
Post #74335 31st Jul 2011 3:17pm
