Home > Technical (L322) > jacking points and suspension |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
On the toolbar under the FFRR website banner there is a section called "Wiki" - have you looked in there as there for the info? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
31st Jul 2011 7:56am |
FWIW, I follow the basic rules of drop suspension into access height to relieve the pressure in the airbags. Disconnect battery so the car doesn't try to self level. Jack under the suspension arms and put axle stands under the main jacking points.
31st Jul 2011 8:31am |
Go to the wiki, find the download link to the RAVE and read before starting. This is not a 1971 Ford Cortina. Even disconnecting the battery can become an expensive mistake if you don't follow the proper procedure.
31st Jul 2011 12:21pm |
E18RLY Member Since: 02 Jun 2011 Location: sout shields Posts: 29 |
Cheers al check it out now thanks for the advice |
31st Jul 2011 3:17pm |
