![]() | Home > Technical (L460) > Left flasher double speed |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35598 ![]() ![]() |
what about the door mirror indicator ? ... - .- -.
vanquishspirit Member Since: 10 Feb 2012 Location: United Kingdom Posts: 131 ![]() ![]() |
Doh ! I forgot that. Thanks will check . Too much Xmas cheer clearly 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
well eventually I remembered to check and its not that! All indicators are working the same left and right except left is double speed inside the vehicle! One thing I did discover is that there are indicators in the lower valance which only operate when the tailgate is raised.....who knew? Well not me anyway.. I suppose it stands to reason if you have hazards on and the tailgate up. Anyway, so back to the problem I guess thats one for the diagnostic machine when she goes in next. 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
Freddy Bear Member Since: 10 Jan 2019 Location: London Posts: 160 ![]() ![]() |
I had this problem on my car too. Land Rover Assist diagnosed a faulty front light unit, but in discussion with other technicians Land Rover Bedford identified the indicator stalk unit as being the cause. And they were right because once it was changed the problem was solved. I am sure your dealer will be able to help - at least it is a known fault.
thank you for that Freddy. Yes I very much enjoy the car, its a total joy. 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
