Home > Maintenance & Mods (L322) > Rear window wiper help
LIIICHT
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hi there, I'm trying to diagnose a non functioning rear window wiper. The wash isn't working either.
I've pulled the wiring off the motor to check there is power going to the unit and there is. Brown wire being earth and red white 12v live. Now I assume the blue and red wire is switched live from the stalk. There doesn't seem to be any power going to it when the rear wash wipe is activated so am I looking at a broken wire somewhere? I don't want to shell out for a new motor if it's a wiring issue somewhere. Can anyone shed any light?
Thanks
Post #680728 19th Dec 2023 10:38am
LIIICHT
The car is a 2006 L322 btw
Post #680729 19th Dec 2023 10:39am
Phoenix
Post #680737 19th Dec 2023 11:56am
LIIICHT
Cheers Phoenix.
Yeah I've pulled the motor out and taken the cover off and it's pretty nasty inside. I'll try giving it all a clean up but it's maybe kaput.
Post #680742 19th Dec 2023 12:32pm
Phoenix
Post #680743 19th Dec 2023 12:59pm
LIIICHT
Thanks ๐Ÿ‘Œ
Post #680744 19th Dec 2023 1:10pm
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
My rear washers just trickle rather than spray like the windscreen ones, is this normal ? RR owner
Post #680762 19th Dec 2023 5:21pm
probably down to old age.. .... Laughing ... - .- -.
Post #680765 19th Dec 2023 5:26pm
Old-un
Rolling with laughter RR owner
Post #680766 19th Dec 2023 5:28pm
Wiltshire130
United Kingdom 2018 Range Rover Autobiography 5.0 SC V8 Corris Grey
Having had trouble with my rear wiper this week I was trying to test the washer and found it did not function with the tailgate open. In hindsight, not unreasonable, but did confuse me initially. L405 2018 5.0 S/C
Post #680843 20th Dec 2023 5:39pm
supershuttle
You sure you don't mean dribble rather than trickle Rolling with laughter Geoff
Post #680848 20th Dec 2023 7:05pm
Old-un
OK good fun but any serious responses also welcome. Smile RR owner
Post #680869 20th Dec 2023 11:29pm
mjdronfield
Wiper will stop if you open the tailgate when itโ€™s moving.
The L322 has always suffered with dribbles from the washer at some point. The water feed goes through the motor and any leak or blockage results in the mechanism getting rusty, hardly any water coming out and brown rusty water ending up leaking out behind the headlining.
There is a little in line non return valve that can sometimes get blocked.
Ended up having to fit a new motor when I had the TD6.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #680870 20th Dec 2023 11:50pm
