Home > Maintenance & Mods (L322) > Extra reversing lights ?
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Playing with idea of fitting extra reversing light somewhere under the car or maybe even "flush fit" ones in the bottom of the rear bumper.
Will they just splice into the existing loom or do they need a special relay or some other trickery in the BCM done ?
The stock ones are next to useless and I'd like the reversing lights at a lower point on the car.
Cheers, Ard
Post #680496 16th Dec 2023 9:50pm
mjdronfield
These might be a tidy option…
https://www.ebay.co.uk/itm/222931856670?ep...UJCFyMaOYw
Or folk sometimes mount other types underneath the rear bumper, more out of sight.
No idea about wiring though
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #680497 16th Dec 2023 9:58pm
Tiprat
Good evening, I did exactly that, bought a pair of slim led spotlights, spliced the wiring, ran the positive and negative through the rubber bung, drilled two small holes in the underneath of the bumper, just before the end of the bumper, tightened the nut onto the threaded bar with a washer either side.
Now when she selects reverse it lights up the area behind the car, and the picture on the screen is so easy to see it makes reversing so much simpler, I also made sure to keep the light pattern horizontal so that it didn't blind any one or other road users, when reverse was selected.
The lights were a cheap set off eBay, about 1inch by 6inches and they've been on at least 3 years with no issues. Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #680498 16th Dec 2023 10:10pm
V8 Bob
I changed the originals for some from Powerful Uk much better light. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #680499 16th Dec 2023 10:20pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Looking to do the same as reversing at night is entertaining to say the least, any issues with MOT having 4 reverse lights or are they switchable? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #680514 17th Dec 2023 8:34am
Tiprat
They are not switchable, i never thought about that when I fitted them. However the vehicle has been MOT'd at 3 different garages due to where I was and which garage could fit me in. And no one has said anything about it. Borrowed Grey 2002 3d 204k for a year
Post #680515 17th Dec 2023 8:52am
Paul H
Actually just checked and the requirement is for at least one and doesn't mention an upper limit..... was convinced it was a max of 2
https://www.gov.uk/guidance/mot-inspection...tion-4-6-1 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #680516 17th Dec 2023 9:21am
Dutchgit
Exactly what I had in mind. Just ordered some 6X1 inch work lights.
Post #680522 17th Dec 2023 10:02am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
Not sure if the same applies to earlier L322s but my 2012 uses H6 bulbs in the reversing lights.
Rubbish for sure so I opted for a pair of these:
https://www.ebay.co.uk/itm/304929104766
No alarms, need a bit of fettling to seat as they are pretty long, but very bright and no need to change the looks.
Cheers
Andy
Post #680529 17th Dec 2023 12:34pm
Dutchgit
Thanks Andy, I looked at a solution like that but I'd like a better view of the ground directly behind and possibly underneath the car as well.
I had twin axle trailer a while back and mounted a LED worklight directly behind the rear axle on that to illuminate the ground under and behind it which was a treat in reversing as it also cast a shadow where the rear tyres where.
Need to order me a new reversing cam as well methinks Rolling Eyes
Post #680560 17th Dec 2023 6:46pm
Spaniels
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Barolo Black
Hi Tiprat, I've been thinking about doing something like this for a while, was it easy to install in terms connecting to the wiring system for the reserve lights? I'm not the best with electrics on cars... Did you get them from these guys, thanks
Post #684990 7th Feb 2024 8:04pm
Tiprat
No there not the one, my link has disappeared so I can't send it to you, if you DM me I shall try and take some photos of them and send them to you, and yes they were really easy to wire in, two additional wire of the correct length spliced into the main loom for the positives and then just spliced into the nearest earth. Two 8mm holes into the bottom lip of the bumper apox 1 inch from the end. Pushed the bolts through then a washer and tightened up. Select reverse and on they come. Borrowed Grey 2002 3d 204k for a year
Post #685081 8th Feb 2024 1:58pm
Spaniels
Thanks Tiprat, will DM you.
Post #685112 8th Feb 2024 6:53pm
