![]() | Home > Maintenance & Mods (L322) > Extra reversing lights ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
These might be a tidy option…
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 93 ![]() ![]() ![]() |
Good evening, I did exactly that, bought a pair of slim led spotlights, spliced the wiring, ran the positive and negative through the rubber bung, drilled two small holes in the underneath of the bumper, just before the end of the bumper, tightened the nut onto the threaded bar with a washer either side.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
I changed the originals for some from Powerful Uk much better light. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 79 ![]() ![]() ![]() |
Looking to do the same as reversing at night is entertaining to say the least, any issues with MOT having 4 reverse lights or are they switchable? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
They are not switchable, i never thought about that when I fitted them. However the vehicle has been MOT'd at 3 different garages due to where I was and which garage could fit me in. And no one has said anything about it. Borrowed Grey 2002 3d 204k for a year
Actually just checked and the requirement is for at least one and doesn't mention an upper limit..... was convinced it was a max of 2
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
Exactly what I had in mind. Just ordered some 6X1 inch work lights. |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi,
Thanks Andy, I looked at a solution like that but I'd like a better view of the ground directly behind and possibly underneath the car as well.
Spaniels Member Since: 10 Apr 2022 Location: South West Posts: 2 ![]() ![]() ![]() |
Hi Tiprat, I've been thinking about doing something like this for a while, was it easy to install in terms connecting to the wiring system for the reserve lights? I'm not the best with electrics on cars... Did you get them from these guys, thanks https://www.ebay.co.uk/itm/222931856670?ep...UJCFyMaOYw |
No there not the one, my link has disappeared so I can't send it to you, if you DM me I shall try and take some photos of them and send them to you, and yes they were really easy to wire in, two additional wire of the correct length spliced into the main loom for the positives and then just spliced into the nearest earth. Two 8mm holes into the bottom lip of the bumper apox 1 inch from the end. Pushed the bolts through then a washer and tightened up. Select reverse and on they come. Borrowed Grey 2002 3d 204k for a year
Thanks Tiprat, will DM you. |
