Home > Maintenance & Mods (L322) > 4.4 TDV8 ZF8 Gearbox Remap
hotpotatojr
Hi,
Not intended as a thread for debate on why one should want such a thing doing (but feel free if you must Smile )
But does anyone have any knowledge/experience of the ZF8 being 'remapped' in a Range Rover? I can't find anything on the inter-web that isn't BMW related.
Thanks
Post #679864 9th Dec 2023 10:29am
JayGee
Never heard of it although I have had a software update on mine which changed it's 'feel'. 2012 TDV8 Vogue (L322)
Post #679866 9th Dec 2023 10:45am
hotpotatojr
Was that via IID? Was it worth it? I've considered it too, but still interested to see if anyone has/can map them for this car.
Thanks
Post #679871 9th Dec 2023 11:34am
JayGee
It's dealer access software only. Not sure it was 'worth it' but it's probably a good idea to have the latest software that benefits many years of use and adjustment on the L405. 2012 TDV8 Vogue (L322)
Post #679872 9th Dec 2023 11:40am
GraemeS
After-markets ZF8 updates are available. There's a person in AU who does the update which wasn't developed in AU although may have had some input but it should be available in the UK. It is oferred here either stand-alone or packaged with a pcm update for a reduced price. I'm very happy with mine's EGR delete + minor performance enhancement and the standard gearbox mapping which works very well for my usage.
Post #679909 9th Dec 2023 7:40pm
garyRR
I enquired with various tuners about this a few years ago.
Land Rover used their own ECU for this gearbox and not the ZF ECU (which you will have read about people being able to remap), namely on BMWs. The Land Rover ECU used is locked and it's not possible to remap the gearbox ECU.
Good results can be had from a remap of the engine ECU however, to alter timings and deliver a more instant response. 2015 Range Rover Autobiography 4.4 SDV8
Post #679933 9th Dec 2023 10:36pm
I believe all "aftermarket" gearbox remaps are pretty much adaption resets! So be careful not to get ripped off ladies & gents... Whistle
Post #679934 9th Dec 2023 10:56pm
GraemeS
https://www.aulro.com/afvb/the-verandah/28...8hp70.html
Post #679942 10th Dec 2023 7:24am
