Home > Maintenance & Mods (L405) > Anti-Rollbar 'D' bushes front & Rear
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
H all, 2019 L405 Autobiography, 54K miles, just been into main stealer for a 64K service (I know but I didn't pay for the service so had no choice!). The only things that they have picked up as advisories are the following;
'front d bushes have slight play'
'rear d bushes have slight play'
Firstly, what are these 'd' bushes that they are referring to? Are they anti-rollbar bushes?
Are they expensive?
Are they a big job to replace, is it something a DIY'er with limited knowledge and tools could do on the driveway?
If it is the anti-rollbar bushes are there improved versions that people could recommend that I should replace with?
I did not dare ask the main stealer for a quote as I wouldn't give them the satisfaction!
Any guidance greatly appreciated as always.
Post #679539 5th Dec 2023 2:13pm
JamboM3
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
I’ve just had mine done (2017/62k).
D bushes are the bush surrounding the bar linking it to the car At the end of the bar are what are referred to as “Links” and would be advised to replace at the same time. It’s DIY-able depending on equipment skill time and patience.
Post #679687 7th Dec 2023 10:46am
There are revised bushes available from JLR, they have a return rim on the edge... Hopefully someone might know the part number?
Craig Thumbs Up
Post #679738 7th Dec 2023 7:31pm
knwatkins
Part number LR048451.
Dead easy to change on the driveway. 4 bolts, drop the arb, clean, replace bushes and refit. I'd say I had mine done in 30 mins. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #679822 8th Dec 2023 6:14pm
knwatkins
^^^ that's the fronts by the way. Kev
Post #679823 8th Dec 2023 6:22pm
Thumbs Up Thumbs Up Thumbs Up
Post #679849 9th Dec 2023 12:18am
ReggieMac
I have been quoted some really silly prices; I asked for prices for front & rear bushes and drop links
JLR £432 PARTS ONLY
Local Garage £863 Parts and fitting
So I am really hoping I an do this myself. Obviously the JLR price is for genuine parts but even then I am sure the genuine parts from elsewhere would be cheaper?
For those who have replaced these bushes and maybe also the drop links, did you use genuine parts?
I am getting really confused trying to identify the part numbers I need though. Smile
Post #679877 9th Dec 2023 2:26pm
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Which engine do you have?
Do you have the active anti-roll? 2017 (67) Vogue SE Corinthian Grey
Post #679880 9th Dec 2023 2:56pm
Phoenix
Post #679881 9th Dec 2023 3:12pm
ReggieMac
I am not entirely sure, I have the 4.4 V8 Diesel and according to my build sheet my suspension includes 'ACE'?
Post #679891 9th Dec 2023 4:09pm
ReggieMac
Phoenix wrote:
You should also be replacing the nuts & bolts - especially the bolts as they are torque+angle so will have stretched (intentionally) Meyle bushes part number 53-14 615 0013 were £36 for a pair when I did mine recently.
DON'T use air or battery tools to release the torque on the bolts, they are direct into the Aluminium frame and could potentially damage the threads if not removed 'sympathetically' The bolts & nuts (front only) were about £30 from Duckworths.
That is very useful as nobody I have spoken to so far has mentioned nuts and bolts, are these nuts and bolts for the anti-rollbar bush brackets or for the drop-links?
Post #679892 9th Dec 2023 4:10pm
Phoenix
Post #679895 9th Dec 2023 4:41pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Part numbers of nuts, bolts and bushes are in this thread
Post #679904 9th Dec 2023 6:53pm
ReggieMac
That is excellent, thank you very much that helps considerably! Thumbs Up Bow down
Post #679905 9th Dec 2023 6:58pm
