![]() | Home > Technical (L322) > Quick Q regarding window regulator |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
In all likelihood, the motor is probably fine - you can test it once you've got the assembly removed and keep as a spare.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
There’s a plastic clip that holds the ends of the lift cable. I had one end of the clip break off and the cable popped out so the window wouldn’t go up. I probably could have fabricated a repair but I had a spare regulator that I’d been given (in an old door). Ron B. VK2OTC
camcc Member Since: 01 Oct 2023 Location: Godalming, Surrey Posts: 38 ![]() ![]() |
Thanks both that's useful. I'll be sourcing a complete regulator & motor online. 2005 L322 4.4 AJV8 |
Pix here:
2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
