Home > Technical (L322) > Quick Q regarding window regulator
camcc
Hi all,
I think one of my rear window regulators has gone. A passenger put their window down the other day, there was a loud snap and now the window won't go back up! I managed to manually pull the glass up and jam in a trim removal tool to stop it dropping again.
I'm intending to get the door card off and assess the issue/damage as soon as it stops bl**dy raining (the fatty is too big to fit in my garage).
Question: is it wise/typical to replace the whole window regulator (frame and motor) or just the motor? There is a bit of a price difference between the motor on its own (£15) and the whole thing (£80-200).
If anyone has a regulator/motor for sale, send me a PM. 2005 L322 4.4 AJV8
Post #681792 3rd Jan 2024 4:03pm
garyRR
In all likelihood, the motor is probably fine - you can test it once you've got the assembly removed and keep as a spare.
A whole new assembly including motor is around £70 on ebay or £100 from a specialist like lrdirect.
Having rebuilt a regulator assembly before, and needing to wind the motor workings and tension the cables, I'd say it's 10x easier just to replace the whole thing. 2015 Range Rover Autobiography 4.4 SDV8
Post #681829 4th Jan 2024 3:56am
p38arover
Australia
There’s a plastic clip that holds the ends of the lift cable. I had one end of the clip break off and the cable popped out so the window wouldn’t go up. I probably could have fabricated a repair but I had a spare regulator that I’d been given (in an old door). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #681851 4th Jan 2024 11:31am
camcc
Thanks both that's useful. I'll be sourcing a complete regulator & motor online. 2005 L322 4.4 AJV8
Post #682048 7th Jan 2024 10:05am
p38arover
Australia
Pix here:
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #682127 8th Jan 2024 1:33am
