Home > Technical (L322) > Timed climate |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 269 |
Yes it should trigger when ambient temperature is low ( below 8 degrees C I think ). It can be switched on manually from the touch screen menu, programmed on a timer from the touch screen menu or triggered remotely with a dedicated key fob. If the battery voltage or fuel level is too low it won’t fire up or, if operating, will shut down.
2nd Dec 2023 5:40am |
Jaysto Member Since: 23 Oct 2023 Location: Liverpool Posts: 13 |
Just tried with ignition off.
2nd Dec 2023 9:56pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1463 |
I used to get this. Do you hear the clicking of the FBH fuel pump start?
2nd Dec 2023 11:48pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4298 |
Or if the battery is getting old it will cut out shortly after fire up. I have this currently as battery is 5 years old and due a swap out Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Dec 2023 9:47am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 795 |
On the MY 10-12, the FBH will provide cabin heat <15 degrees C
3rd Dec 2023 12:02pm |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 653 |
Have you checked the fuse? Mine used to fire up for 5 seconds then turn off. Found the fuse missing so replaced and now works like a dream. |
3rd Dec 2023 4:20pm |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 |
Could be the coolant pump on the FBH that's given up or has a corroded contact or such. |
3rd Dec 2023 6:27pm |
