Home > In Car Electronics (L405) > Stationary Voltage.
MykeH
Stationary Voltage.
L405 2017 4.4 AB. My new tracker has been producing false alerts and the supplier, having checked it out, advises that he has seen the tracker receiving a voltage as high as 13.46 when the vehicle is at rest. The tracker's trigger is 13.4 volts (which explains the false alerts) and I wonder if this is typical 'resting voltage' or might it indicate a fault? I don't want him to increase the tracker's trigger voltage if I need to be attending to something else first.
I'd much appreciate any advice from anyone who has experienced anything similar. Thanks in anticipation.
Post #679150 30th Nov 2023 2:37pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
By "at rest" do you mean with the engine still running though? FFRR SDV8 Autobiography
Post #679153 30th Nov 2023 3:16pm
MykeH
No James. I mean when parked up, shut down and locked up. I think 14.5 v is not unusual when the eng8ne is running but I don't know how high the voltage can go when it's not running.
Post #679154 30th Nov 2023 3:24pm
Phoenix
Post #679156 30th Nov 2023 3:48pm
MykeH
Thank you Phoenix. I'll need to ask the question of the fitter, but the vehicle had been switched off for more than 24 hours before a false alert. Would that make a difference?
Post #679158 30th Nov 2023 3:56pm
Phoenix
Post #679177 30th Nov 2023 7:19pm
MykeH
Thanks for your advice. I'll need to do some checking with the fitters, now, and establish what they chose to do. It looks as if I may need to get the tracker reinstalled.
Post #679178 30th Nov 2023 8:05pm
