![]() | Home > In Car Electronics (L405) > Failed 22a Software Update |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233 ![]() ![]() ![]() |
Is that the 1/12/22 update? Is there no more recent update now that Pivi Pro reigns supreme. Are those of us with In Control now considered to be not worthy of software updates? Grr! |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1678 ![]() ![]() ![]() |
Hi Nubbin,
I agree with that for sure! I've just had the free security update done on mine, and asked the dealer about updates - they thought I meant vehicle software and gave me a "If it ain't broke..." line, saying that if they updated the vehicle and something didn't work, it could easily cost ME (!) £2-3000 to fix!
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
Never bothered with the car sat nav, always have Waze on CarPlay. As for 22a, connection etc seems fine, but it does very occasionally simply not work when you turn on the ignition - two black screens which need a turn off-lock-unlock-turn on again. |
LiKuid Member Since: 05 Dec 2024 Location: Athens Posts: 25 ![]() ![]() ![]() |
Anybody knows if i can reinstall an already installed software version?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
would a battery disconnection help? ... - .- -.
@LiKuid:
As per this thread:
thanks for that. I know that it is wired, although i ve forgotten about it in the first place. The thing is that given i ve got a usb-c iphone, i used a non genuine USB A to C cable which also may cause issues. So, i used my wife's iphone (lightning) with a genuine cable but still to no avail... Both USBs should work for carplay. Correct? |
Is Carplay enabled on the phones, and in the car menu? “If it ain’t broke, don’t fix it” -where’s the fun in that? |
How do you enable carplay in the car menu?
I had a LOT of problems updating software, caused by lack of voltage from a weak battery, as soon as I changed the battery, everything worked perfectly, so check the. Battery SOH (rather than SOC). Switching on the ignition without the engine running will cause a drop of almost one volt, so if battery is old, it may be too low. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
You may need 22A for Carplay, maybe someone can confirm? “If it ain’t broke, don’t fix it” -where’s the fun in that? |
I am on S22A_22.32
